I have read, viewed every possible piece of information on how to remove the window crank handle. I GIVE UP!
I'm going to cut mine off with a dremel tool and buy replacements from ebay that are NORMAL.
I have used the rag over and over. I have used the tool made for this and only managed to scratch up my door panel real bad. I have tried to hook it with bent wires. I have really gotten frustrated over this stupid handle.
It's a spring C-clip over a notch or groove on the shaft. You'll have to replace the regulator if you cut it.
I figure if I just cut it just deep enough to crack the plastic that I can chisel it apart. I got 2 on order from ebay that have more exposed clips that are easier to get to. I dont intend to grind into the spline.
