Originally posted by pdxdennis@Nov 7 2004, 06:53 PM
i have a Hyundai Sonata 2000 it it set out side for the windows fogs up and i get moisture on the inside. I know a small amount is normanl but this is way to much. Anyone know what causes this and what i can do about it.
[snapback]2441[/snapback]
Originally posted by gordo@Nov 8 2004, 10:48 AM
You may have a water leak or a clogged drain somewhere - Suggest checking the trunk as well (be sure to check the spare tire well)
Try pressing a dry paper towel into the carpet - if it comes up wet then water is getting in somewhere.
[snapback]2468[/snapback]
Originally posted by pdxdennis@Nov 9 2004, 06:57 PM
nothing in the spare tire. bu i did find out the carpet is wet on the passage side
[snapback]2530[/snapback]
