I have difficulties when the authomatic system operate the close of the windows, at the end of the car Operation ( when you arrive and park).
The motors have not the necessary force to operate at the same time and to obey at the authomatic window close.
It is only possible if you have the care of maintaining perfectly lubricated de guides of the glases.
Have anybody had the same problem ? .
Isn't it better, Factory have had released most power to the Windows Motors ?
I expect your Opinion.
Regards
Selenico77
If the problem is the same on all the windows then it could be your battery is no longer holding a full charge. If it was just wear on the mechanism then some of the windows would go up faster than the others.
With the engine stopped and the ignition on, try switching on the headlights, fan, wipers, etc. If that makes a difference to the power windows, then it is your battery.
You could also have all the window motors serviced. That would involve removing the door panels and cleaning the mechanism inside the doors. The track inside the door can also be cleaned and adjusted at the same time.
You may need to take it to a garage to do that because if you don't get the door panels on right they will bind on the windows and make the problem worse.
[snapback]1643[/snapback]​
Thanks GORDO for your Concern.
I shall go trought those tests.
Best Regards.
Selenico 77
