Whenever I step on the gas from a stop or from a slow roll the car hesitates. The longer I keep my foot in it the more it does it. If I keep my foot in it, it will eventually misfire. It will misfire on different cylinders. One time it was cylinder 2, I cleared it, then another time was cylinder 3. Occasionally at a stop sign she will shudder. Especially on an incline with my foot off the brake.
BUT if I accelerate slowly there are no problems. **** I can even floor it at 40 mph, she will drop the gear and take off no problem. Sounds healthy as ****.
So far I have changed the coil pack, wires, spark plugs (recently rechecked and good), the fuel pump, fuel filter, the fuel pressure regulator, the MAF, the TPS, and the Idle air control valve. I also completely cleaned the throttle body and checked for vacuum leaks in the intake.
She currently has a cold air intake, long tube hedders, a test pipe, and a cat-back exhaust. I’m using a mini-catalytic converter insert to dupe the check engine light.
What is wrong with her? I’m out of ideas.
