1 - 20 of 73 Posts
DI5 5 Spoke Lip ET:35 PCD:4 x 100 CB:56.1; Black & Blue [77-99100]
DI5 5 Spoke Lip ET:35 PCD:4 x 100 CB:56.1; Black & Red [77-99101]
DI5 5 Spoke Lip ET:35 PCD:5 x 114.3 CB:70.3 ; Black & Blue [77-99103]
DI5 5 Spoke Lip ET:40 PCD:4 x 100 CB:56.1; Black & Blue [77-99106]
DI5 5 Spoke Lip ET:40 PCD:5 x 114.3 CB:70.3; Black & Blue [77-99109]
DI5 5 Spoke Lip ET:40 PCD:5 x 114.3 CB:70.3; Black & Red [77-99110]
DI5 5 Spoke Lip ET:45 PCD:4 x 100 CB:56.1 ; Black & Blue [77-99112]
DI5 5 Spoke Lip ET:45 PCD:5 x 114.3 CB:70.3; Black & Blue [77-99115]
I'm gonna order them.  Just need to know which one first.  Here's the wheels: http://www.streetbeatcustoms.com/Option-Ra...et-of-4/610917/
I would do these since they are 40mm and 4x100: DI5 5 Spoke Lip ET:40 PCD:4 x 100 CB:56.1; Black & Blue [77-99106]
I can't remember the center bore for our tires off hand (was it 46ish??) It is somewhere on the forums. Make sure you get the correct hubcentric rings, some places sell em with the rims.
QUOTE (Leprakong @ Aug 24 2010, 01:39 AM) index.php?act=findpost&pid=351529
Definitely these ones:
and you'll need hubcentric rings to bring the centerbore down from 56.1mm to 54.1mm
I just put 40 offset Enkei's on my car and they sit perfect no rubbing or anything silly like that...
QUOTE (Leprakong @ Aug 24 2010, 09:38 AM) index.php?act=findpost&pid=351577
Thanks so much. Hopefully I could order them in 2 weeks.
 Is there a certan kind/spec hubcentric ring I need? And you think A&A auto might sell them?
As long as you get one from 56.1 to 54.1 brand doesn't matter... Might want to ask the wheel vendor if they stock them as well... Get them as a package deal they run from $15-$25 for a set of 4...
Are you sure you want 15" wheels? They look pretty small on Accents. Best size is 16 or 17". Anyway, they must be 15x6" wheels so I would recommend these: DI5 5 Spoke Lip ET:35 PCD:4 x 100 CB:56.1; Black & Blue [77-99100]
The lower offset will bring the wheels out and closer to the fender instead of tucking them deep into the wheel wells. ET40 is close to OEM but OEM stance sucks, the wheels are inboard too much even with the 16" alloys.
QUOTE (burnitwithfire @ Aug 24 2010, 06:04 PM) index.php?act=findpost&pid=351730
Yeah but if you run too low of an offset you side load your wheel bearings I'd rather less desireable looks than a lifetime of putting wheel bearings in a car....
QUOTE (berserko @ Aug 24 2010, 07:35 PM) index.php?act=findpost&pid=351747
I doubt 5mm is going to severely reduce your wheel bearing's life expectancy. I'm running a 7.5" wide wheel with a 38mm offset and no issues so far. I see people running on much more agressive setups without problems.
Discussion Starter #9
The reason I want these is for the design.  Love the looks of them.  If they got bigger, I would get bigger, but the biggest size they come in is 15". Plus, since I live in pa (terrible roads) It would suck to have thinner tires...
So the bearings won't be an issue than?
absolutely not. stock offset on the oem 16's is +47, going to +40 or even +35 is hardly a difference and will not compromise your wheel bearings.
if you made a huge change to something like +0 offset (which you would have to do some work to make it fit and look right) then yea you might wear out your bearings quicker, but they would still last you a few years before needing to be replaced. btdt.
40 sits sort of flush in the front with stock height and alignment, its a little more tucked into the wheel well in the rear. 195/55 will keep your tires closer to stock diameter, I am running 205/50.
I agree, the 15's looked a little small at stock ride height, but I like them with the car lowered. Have yet to get my 16's back on the car but they are going to be hella sunken battleship.
Discussion Starter #11
Thank you very much everyone. I guess I'll go with the DI5 5 Spoke Lip ET:35 PCD:4 x 100 CB:56.1; Black & Blue [77-99100] since it'll look better and won't harm anything.
Discussion Starter #12
THE SHIPPING IS $150!!!!! Gahhh! That brings them from 216.99 to 367.98. That's how much I freakin' make in a week. and I could have  put that towards the new tires.
Damit.  I'm still getting them.  And most likely the day after tomorrow. I just wish for that much money, that they were bigger.  They're still bigger than my stock stupid looking hubcaps.
Discussion Starter #14
Haha.  Yea.  Ebay is rediculous sometimes.
I just ordered them, and it should take 5-7 business days for them to get to my house.  :D So excited to get rid of those tacky plastic things.  Then I have to get new tires...
They may fit, but there might not be a large enough space to fit the lug wrench on them. In that case you will need some spline drive lug nuts.
I have always used Gorilla Lug Nuts. I ordered mine from summit racing, their shipping is usually super fast. I forget the thread pitch but its on the forums here somewhere.
I have taken my lugs off and on so many times, they are still not scratched (anodized black finish)
Discussion Starter #17
Alrighty.  Thanks. I was looking in a&a auto for some hub centric rings, and found alot of different size lug nuts.  Maybe they'll have those.  I'll look into it if mine don't fit.  But they didn't have the size hub centric rings I need.  Anywhere online? I'm gonna check advance auto tomorrow, but I highly doubt they'll have them if A&A doesn't. They didn't even have them in their catalog.
1 - 20 of 73 Posts
