Thanks, I went on the site but they don`t have the specs for the 2005. I left the question in the GPS forum, thank you for the info.
QUOTE (Spawn @ Apr 19 2010, 08:48 AM) index.php?act=findpost&pid=314531
Which wires are you looking for exactly??
I am looking for the wire that makes the brake icon appear on dash when you pull on the parking brake (emergency hand brake) and also the wire that activates the rear back up lights, I don`t know if the wire colour at the tail light is the same colour as the one at the fuse box.
Do you need them at the instrument cluster, or at another location?
This is from HMAservice.som
PARKING BRAKE SWITCH
1. Check that there is continuity between the terminal and switch body with the switch ON (Lever is pulled).
2. Check that there is no continuity between the terminal and switch body with the switch OFF (Lever is released).
Thanks I looked on the hma site and I guess I missed that page. I`ll hook it up there though I was hoping not to have to take the center console apart but then again it must be the same colour wire at the fuse box, Thanks for the info.
