My low beam headlights both stopped working.
High beams work, bulbs good but can not find the correct fuse for the headlights.
What is it marked as?
Are there more than one fuse, left & right?
So frustrating.
Ak, I have attached three schematic diagrams that you can review. From your
description, the situation sounds a bit odd and you may find that the issue is not
a fuse. I would recommend you double check the bulbs in question. You
will find the Engine Room Fuse Box on the driver's side and the lid should have
a picture of the layout you see in one of the attachments. Yes, there are a couple
of fuses. Let us know what you find. I assume you are driving a DM Santa Fe, so
the drawings should work for your questions. Hope this helps.
Good luck,
Paul
