1 - 20 of 44 Posts
I've seen this done on a lot of other forums... we can put together a thread where we all show some pictures of our car and describe the wheel/tire/suspension combination we're running. It is a really useful resource when you are shopping for parts.
I'll get things rolling, but here is the basic template we should try to stick to to keep the thread useful.
Wheel Size:
Wheel Offset:
Wheel Brand/Model:
Tire Size:
Tire Brand/Model:
Suspension:
Issues: Do you rub? Need spacers? Tell us here.
Notes: If you have any other notes/review about the products listed, feel free to add that (like if the tires you bought suck, didn't wear well, etc...). Other specs like how much your wheel/tire combo weighs would be nice, but I know that is not always easy to come by.
Pictures: A few shots to give us an idea what it looks like.
Mine:
Wheel Size: 15 x 7
Wheel Offset: ET+42
Wheel Brand/Model: TR Motorsports C1
Tire Size: 225/50R15
Tire Brand/Model: Kumho Ecsta AST
Suspension: Stock (GS)
Issues: No rubbing. No Spacers.
Notes: Not much to say about the tires so far. I did take the time to weigh one of the wheels, it was about 33lbs with the tire mounted. The wheel is supposed to be about 12.5lbs.
Pictures:
Mounted on the car:
Stacked next to the stock tires (175/70R14) on 14 x 6 VW Snowflakes:
The 225 width compared to the stock 175 width:
QUOTE (WeirdGermanAccent @ May 12 2010, 06:52 PM) index.php?act=findpost&pid=322230
That's a good idea
I don't have the wheels yet, probably next week but I got specs
Wheel Size: 16x7.5
Wheel Offset: +38
Wheel Brand/Model: Sport Edition A7
Tire Size: 205/45 R16
Suspension: Stock Canadian base model
Issues: None except noisy worn tires
Notes: Require tuner style nuts, 72.62mm center bore, 60mm center cap, 2010 Accent center bore is 54.1mm
Pictures:
Wheel Size: 17x7.5
Wheel Offset: +40
Wheel Brand/Model: TIG T5
Tire Size: 215/40ZR17
Tire Brand/Model: Nexen N3000
Suspension: Stock GS
Issues: Heavy/Tall - Slower Acceleration, Speedo off.
Notes: Come with lug centric, security lugnuts.
Pictures: Long gone.
Wheel Size: 17x7
Wheel Offset: +40 mm
Wheel Brand/Model: SSC Performance Style 675
Tire Size: 205/40/17
Tire Brand/Model: Falken ZE-912
Suspension: SMA Coilovers
Issues: Speedo off.
Notes: If your city have bad roads, do not buy this type of tires. You will feel all the bumps on the road.
Pictures:
Wheel Size: 18x7.5
Wheel Offset: +42
Wheel Brand/Model: Drag / dr18
Tire Size: 215/35/18
Tire Brand/Model: kumho ecsta mx
Suspension: Stock
Issues: No issues so far.
Notes: Would not recomend if you are looking for comfort. very bumpy and a bit louder on highway. Does feel sluggish due to the increased weight
Pictures: Black on Black
Wheel Size: 16x6.5?
Wheel Offset: +47
Wheel Brand/Model: Oem 16"
Tire Size: 205/45R16
Tire Brand/Model: Kumho Ecsta touring tires
Suspension: oem SE
Issues: Its stock.
Notes: I have read on here the wheels weigh approx. 18 lbs.
Wheel Size: 15x7
Wheel Offset: +40
Wheel Brand/Model: Drag DR30 (silver)
Tire Size: 205/50R15
Tire Brand/Model: Dunlop Direzza DZ101
Suspension: oem SE, custom alignment
Issues: None. Tire diameter is slightly less than stock.
Notes: Wheels around 14-15lbs each.
Wheel Size: 15x7
Wheel Offset: +38
Wheel Brand/Model: Kosei K1
Notes: Friends wheels, Just did a test fit to see how they looked. Wheels are about 13.5lbs each.
Wheel Size: 16x7
Wheel Offset: +38
Wheel Brand/Model: Enkei NT03 (~1999)
Tire Size: 215/45R16
Tire Brand/Model: Kumho Ecsta MX
Issues: None expected. Tire diameter is slightly more than stock.
Notes: Install pending.... Wheels are about 16lbs each. Dry handling expected to be epic.
I believe this thread will be better w/o comments, because, as we know, things get off topic really quick. mod feel free to delete my post and his too and maybe add something on the op about the comments. jmtc
I'm gonna be jumping on new rims, not soon but thats the plan. i'll be getting the SSR SP1 17x9 +24.
This is how my car looks now.
Wheel Size: 17 x 7
Wheel Offset: +42
Wheel Brand/Model: American Racing AR86
Tire Size: 205/40/R17
Tire Brand/Model: Falken 912
Suspension: Stock...for now
Issues: No rubbing cause my diameter is with the 3% range. I could use some spacers for the rear wheels. Like other people have said don't go with anything less than 45 unless you are prepared for the harsh ride!
Notes: I believe the rims weight about 18 lbs each so maybe 25 - 30 lbs with tires? I don't know for sure lol
my old set up
Wheel Size: 16 x 7
Wheel Offset: +40
Wheel Brand/Model: XXR sportmax (don't know model)
Tire Size: 205/45/16
Tire Brand/Model: maxxis MA-V1
Suspension: eibach prokit
Issues: everythnig is going well i'd rocommand similar set up to anybody
Notes: i got 8mm spacer in the back... could be flushness
[attachment=25821:accet_16x7_back.jpg]
[attachment=25822:accent_16x7.jpg]
i'll post my new set up when it's gonna be on in a couple a days/week
nick
Wheel Size: 16x6.5
Wheel Offset: +47
Wheel Brand/Model: OEM SE 16" alloys
Wheel weight: 18 lbs
Tire Brand/Model: Kumho Solus KH16
Suspension: OEM SE struts with B&G lowering springs
Other: H&R Trakplus 20mm wheel adapters in the rear and Eibach 5mm spacers in the front
Issues: Squeaks at low speeds, increased ride harshness. Improved handling makes up for it, though.
TheDarkOne : you're wheel are certainly not 7.5'' wide because on 185 tire you should got a little stretch... they are maybe 6.5''
but i realy like the tow hook!
wath is you're suspension set up (brand and model)
thanks
nick
QUOTE (sleepermc @ May 16 2011, 01:27 PM) index.php?act=findpost&pid=446289
I'd go as far as saying its a 6" wide wheel. I had 205/50 on a 15x6 wheel and it looked similar.
You can kind of see them on this picture
Guess I'll add:
Wheel Size: 16x7
Wheel Offset: +40
Wheel Brand/Model: Drag DR-31
Wheel weight: 17 lbs
Suspension: OEM SE struts with H&R lowering springs
Other: none
Issues: Increased ride harshness. Vastly improved handling makes up for it, though.
1 - 20 of 44 Posts
