Could be a bad axle. Had the same problem so replaced both. Good way to test is when driving up a hill on a highway. Accelerate and see if the steering shakes and then goes away when letting off the gas.
Inner joint concern on offending axle You play with it enough, you can get feel for which side it is, but usually the right side.. had a left side too,, 1 of them was axle not seated fully into differential...
