Would a 18 x 7.5 rim with +42 offset work on my 2011 Sonata SE? The car currently has the 18 x 7.5 factory rims which I am going to use the tires off of on the new rims. I believe the factory offset is +48.
short answer. Yes.
also check this. https://tiresize.com/wheel-offset-calculator/
I just put on a set of 2015 Genesis wheels with a +36 offset 245 45R18 they rub a little. But I also have Eibach springs.
but i would say you are probably ok with 6mm difference.
Cheers
