Ok. So i finally got around to putting on my Vossen CV3's.
Front - 20x9 +35 w/ 245/35/20 Falken Azenis
Rear - 20x10.5 +45 w/275/30/20 Falken Azenis
I dont seem to be having any type of issues with the front wheels. Its the rear wheels im a little concerned about. When i first put the wheels on and took it for a test drive I heard them rubbing. When i inspected the rear wheels i noticed that the tire rubbed against the plastic fender well covering. No biggy. I could always cut that to stop the rubbing. But then i noticed that the wheels were SUPER close to the lower control arms. So close i could barely fit a piece of cardboard in between the back of the wheel and the arm.
I dont here the sound of rubbing anymore. But im not 100% positive what was causing it. It didn't sound like metal to metal (wheel rubbing against control arm) but more of the rubber rubbing against the plastic. Should i be concerned? Maybe get some spacers for the rear wheels just to get them up off the control arms? Are these wheel specs a bit too aggressive for the Sonata?
The rear wheels do poke out a little past the fenders. If i was to lower the car how would i go about tucking the tires in the fender? Ive briefly researched how to roll fenders but i feel as though i would rather have it done professionally when the time comes for a drop.
Thanks for the help
Do you have spacers on?
If you lowered the car then I would consider bags or a decent amount of camber for the rear.
Another RI member in here. Welcome!
No. Not running spacers. But I think I may have too. I dont think bagging it is an option. Wayyyy out of my price range.
Can you please post some pictures of your setup. I want to do a staggered setup on my Sonata but I don't know how 20x10.5 will look like.
