That would be a speedo drive cable . I would say those 2 plastic tabs squeeze in to move it 0r maybe you'll have to disconnect th eother end and pull it forward to clear that retainer. why does it need to come out?
I am taking out the dash to replace the heater core and i only have that left to disconect in order to be able to pull the dash. I have tried disconecting it by squeezing the plastic but it wont move, and I cant acces the back of it to pull the cable out
I think Gerard is right. Detach the cable form the speedo drive at the gearbox, then press in the two plastic tabs on the cable retainer, then pull the cable and it's retainer towards out towards you until it clears the dashboard...
442879
Thanks for the replys. I managed to get it off. First i had to disconect the entire white plastic piece of the gray plastic than disasemble the white piece into 2 parts so than i was able to take everything off.
