It excites the alternator to start the charging process off.
The diode stops any voltage feedback into the ground side when it is switched off.
Are you talking about the preexcitation resistor? This is supposed to be in the passenger compartment, The item I was querying about is in the engine fuse box.
Maybe the drawing I have is not the exact one for my car.
454791
Yes, that is the part in the photo you asked about.
And it is marked as ALT (alternator) on the fusebox cover because it's the alternator excitation resistor.
It's the drawing for a completely different car.
