1 - 12 of 12 Posts
hopefully not KY jelly...
going to be doing a fluid flush on a 2007 elantra auto in the near future...are there any good alternatives to buying the fluid at a premium price from the stealership? any other sources? i'm in canada btw so getting it shipped with our postal laws may not be an option.
A good thread on the subject that might help you out:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2152302
Personally, I try to run Mobil 1 Synthetic ATF when I can. Have not checked to see if it's compatible with an Elantra automatic, as my Elantra is a stick. But running it in my Focus wagon right now and have used it in other past vehicles. The best, in my opinion.
http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_ATF.aspx#
You'd have to do the research and see if Mobil 1 meets the Hyundai spec.
I think this is the OEM fluid available at your dealer:
http://www.werhyundaiparts.com/oem-part/oem-hyundai/atf-sp-iii/0023011000
An expensive option:
http://www.amsoil.com/shop/by-produ...transmission-fluid/?page=/storefront/atf.aspx
I would opine that the type of fluid you use in an Elantra, as long as it meets spec, is a lot less important than changing the fluid at appropriate intervals...something most people neglect.
have to admit i'm not a fan of the multi vehicle fluids...one size fits all usually means one size fits none.
i'll give it a good look though, don't want to put any option out in the cold right yet. thanks.
Retired Staff
I feel the same way about multi use fluids. Manufacturers use specific fluids and design/build/test parts around specific fluids. If a cheaper multi use fluid was acceptable they would probably save money and use it.
Sent from AutoGuide.com App
Discussion Starter · #8 ·
thats exactly how i feel about it.
a multi fluid is designed to meet many specs. the specs are more of a minimum set of properties, oil additive content, etc. a multi spec fluid has to meet all the minimum specs....so if it meets honda, toyota, and hyundai, how do i know what the honda and toyota spec/additives is going to do to my car?
i did read somewhere that hyundai just uses Mitsubishi fluids. kind of like how years ago toyota used GM dexron...any truth to that?
Yes, in fact the Sp standard is actually SP/Diamond standard fluids (Diamond as in Mitsubishi diamond) There is also Chrysler products which used Mitsubishi engines and the Diamond fluids, which later became a cousin to today's ATF +4 products you find in Wally World. I successfully use the cheapo Super Tech +4 product in my Kia sometimes to do a flush, and an OEM Kia SP III flush when I feel rich.
Another safe alternative: Kia dealers also sells the exact same fluid under their name. Was 30% cheaper last time I had to buy some. Think 1st yr Kia Forte had the exact same 4sp trans under the hood.
Have logged over 500k kilometres on several different hyundai's with the Castrol, not a two bit fly by night company.
Would I put it in a brand new 40k$ Genesis under warranty--no.
I bought jugs of dealer sp111 with dealer receit paper trail while still in warranty to avoid BS problems.
The cost savings has allowed me to change tranny fluid more often ; which IMO is even more important.
1 - 12 of 12 Posts
