Hi,
I drive Getz 1.1 2002 with no air con (left side wheel). When it rains water accumulates in driver footwell, I think more to the left because yellow sponge there was soaked unlike the right side where the wheel lath is entering firewall . I checked the door seals, drains beneath the windshield (stick a hose in there), rear washer is working fine, There is no drop in coolant bottle. I am running out of solutions. Any ideas?
Thanks,
Ivan
Discussion Starter · #2 ·
Update...passenger footwell was wet too. With further inspection I figured water is accumulating on a passenger door threshold and entering car above it, so between car door and threshold. How can I fix that, cause door seals seems fine and water is not going under them. Is it possible that water traveled to driver footwell somehow where I first noticed it or I have two leaks. Car is always parked with front end down little bit.
Thanks
