1 - 13 of 13 Posts
At slower speeds (20-40MPH) I feel slight vibrations in the gas pedal. Nothing serious but I feel the difference compared to my other cars. The vibrations go away at higher speeds. Is it normal for Hyundai and I have to learn to do with this or something can be done about it?
Thanks!
QUOTE (Kameha @ Apr 26 2010, 06:54 PM) index.php?act=findpost&pid=317101
Thanks!
I have the same issue with my Nata. I went to the dealership and was told its nothing to worry about. So I asked to test drive a few other vehicles , 07 and a 08, and they both did the same thing at about 40 to 45 mph. After that I was sure it was something the cars does but it doesnt effect anything in a bad way. I could be wrong but if those 2 other vehicles did the same thing, the 07 had like 1700 miles and the 08 had like 12 miles, I just stopped worring about.
Have you actually READ the OP's post, Miami? He's talking about a VIBRATION.......................................... Miami, wake up. Or at least put your glasses on.
It could also be the tires, too much pressure in them? Try lowering to 32 and test again? One of the advantages of our Drive-by-Wire system is that it eliminates any vibrations in the gas pedal.
QUOTE (mamamia @ Apr 26 2010, 06:47 PM) index.php?act=findpost&pid=317130
I know and I did. It is just the Click, Snap, Crackle, or Pop can be felt at the 20 MPH mark that he mentioned, and it got so bad Hyundai had
to issue a TSB. Is this his problem? Most likely not, but when you daily feel a sensation in your Pedal that you have never experienced
in any other Car, why it was worth a mention. :thumbsup:
QUOTE (MiamiLX @ Apr 26 2010, 09:25 PM) index.php?act=findpost&pid=317142
It is just the Click, Snap, Crackle, or Pop can be felt at the 20 MPH mark that he mentioned, and it got so bad Hyundai had to issue a TSB.
??? What TSB? What got so bad? That one-time click is just that, a click, though true, it's not consistent, it can be felt more, sometimes less, sometimes not at all.... and in various low speeds, anywhere between 2 and 10 mph (I don't think it ever waits to reach 20).
But, again, that has absolutely nothing to do with the vibrations the OP has been complaining about...........
Throttle pedal is connected to nothing,, just a plastic mount bolted to floor, with the pedal itself and a position sensor... look under dash at it and see it. Only thing connected to it is a wire harness connector.
Periodically you might experience side effects of ABS self test, that normal, drive on.
1 - 13 of 13 Posts
