Swap the injector with another one and see if the problem follows the injectoor or stays with the cylinder (could be an issue in the wiring harness) as for the reason it starts running bad could be a variety of thing ECU is getting bad signals from the injector and goes into limp mode could be heat related could be alot of things try and diagnose what the fault is by moving the injector might give you more idea where to go next...
