Can anyone help? We have just bought a second hand i10 (2012) which has AUX & USB ports (clearly marked "iPod"). I have tried numerous Apple (and non-Apple) USB-Lightning cables to connect to both an iPhone and an iPod. The display says "Reading" but what is immediately not working is that the phone/iPod pings to say it is charging, then a second later disconnects, then reconnects, then disconnects again, and this process just continues. It is clearly not a problem with the cables so is the solution to replace the AUX/USB module or is it a known problem and replacing the module won't fix anything? Thanks in advance for any insights/advice!
Have you got your settings on your phone set to data only? Might be something to do with that. Try another phone. If that charges then it will be the settings on your own mobile.
Thanks for the reply - I have tried two iPhones and an iPod, all with the same result :-(
I don't believe it's intended to be used in this manner.
I suspect part of the issue could be the limited current capacity of the USB port from the radio
What does the manual say?
CAUTION IN USING THE
iPod DEVICE
• The Hyundai iPod Power Cable is
needed in order to operate iPod
with the audio buttons on the
audio system. The USB cable pro-
vided by Apple may cause mal-
function and should not be used
for Hyundai vehicles.
❋ The Hyundai iPod Power Cable
may be purchased through
your Hyundai Dealership.
• When connecting iPod with the
iPod Power Cable, insert the con-
nector to the multimedia socket
completely. If not inserted com-
pletely, communications between
iPod and audio may be interrupt-
ed.
• When adjusting the sound effects
of the iPod and the audio system,
the sound effects of both devices
will overlap and might reduce or
distort the quality of the sound.
• Deactivate (turn off) the equalizer
function of an iPod when adjust-
ing the audio system's volume,
and turn off the equalizer of the
audio system when using the
equalizer of an iPod.
(Continued)
Features of your vehicle
(Continued)
• When the iPod cable is connect-
ed, the system can be switched to
AUX mode even without iPod
device and may cause noise.
Disconnect the iPod cable when
you are not using the iPod device.
• When not using iPod with car
audio, detach the iPod cable from
iPod. Otherwise, iPod may remain
in accessory mode, and may not
work properly
Hi Gerard 2 - thanks for that. Interestingly, I now remember having the same issue with a Kia some years ago and in the end I never bought a Kia cable. I also remember that Kia and Hyundai share parts so it looks like the solution is to purchase a Hyundai AUX/USB cable. Thanks again - will let you know if it worked...
Ah yes, now you mention it! I think the USB doesn't send out much power. Especially not enough to charge today's huge batteries.
