Hi all....
Did a brief search that didn't yield anything obvious so I decided to make a new thread.
Have a 2010 GLS and have been using an 8 gig jump drive for my music. It works great because its small and out of sight when in use. Besides music I use it for audiobooks which generally have files of 50 to 60 minutes each. Most of the time, I can just leave the car and when I return it resumes right where it left off. Every once in a while it will croak and reset back to the first audio file on the drive. It's a bit of a PIA to have to find exactly where you left off in a big audio file. (assuming I noticed what track I was on when I left)
At first it was only happening on Monday mornings. I only do the audiobooks on weekdays so I figured it might reset if not used in 24 hours or something. Started playing a little bit daily and it helped. I've gotten in the habit of flipping to FM before leaving the car hoping it would help by not killing power abruptly with the key.
None of my little experiments have worked to make it keep its place in the file for more than a week or so. Is there a trick I haven't found yet or is this just a quirk to get used to?
