Hey guys I have a leaky intake manifold, the seal for the primary flow runner has gone and I suspect the plenum seal has gone aswell judging by oil residue. Current symptoms are intermittent and include a resting idle of about 1000-1100rpm. Lack of power below 2000-2500rpm. a lugging sensation when engine braking, manual. The CEL hasn't come on, that and haven't checked for codes.
I'm currently exploring options for getting a salvage intake, aswell as seeing if a machine shop could feasible fix the flow runner seal. Problem being theres an aluminum ring pressed in place holding the assembly together.
Since I have the intake out I'll be checking my plugs. right now I have 245k km/153k miles on what I presume are original plugs. PCV will also be changed out along with the return hose being cleaned out. Lower manifold may come off too pending on what I find, and throttle body gasket will most likely be replaced.
I am currently looking for torque values. I found for the plugs to be 18ft/lbs. But haven't found values for the plenum or the head cover. Which brings me to my second issue.
I've always had a ticking noise like most 2.7l equipped hyundais do, but in the last 1500kms it's gotten ridiculously loud. Hearing it over road and wind noise at 70kph/44mph. And fluctuating with rpm. Feeling the vibrations with my hand I'm suspecting a sticky lifter or something in the front valve head.
I've switched from regular Quaker state 5w20 to there synthetic 5w20 second last oil change. Ignoring buying the "high milage" synthetic oil. Change intervals on regular oil were every 5-6000k km 3750miles, regular QS synthetic was 9000km/5600miles noticed it was a little dark and amber so will be shortening up the change interval.
That is about the only thing I can speculate for now, but since I'm ordering up a list of parts I'd like to take the valve cover off to inspect what is causing such a ruckus
