Hy
my UK 2003 Santa Fe 2.4 came with two remote fobs but only one works properly. They are of the two button type with a red LED light. One functions correctly locking and unlocking, the LED blinking when each button is pressed. The other one will not lock - the LED does not blink when the lock button is pressed. However, it will unlock when the unlock button is pressed and the LED blinks. Is this a case of a faulty fob or does it need re-programming to enable it to lock? Both stickers that were on the back of each fob have been removed at some point so I can't tell what ID or serial number they are supposed to have. If I need to get a replacement will any Hyundai remote fob work or will I need a specific one? I'm thinking of sourcing one from ebay if necessary.
Any help appreciated
Discussion Starter #2
Tried reprogramming both - still have same result so assume fob is faulty. Does anyone know what replacement I should be looking for ( UK spec ) as both stickers with serial numbers/model numbers are missing from both fobs? thanks
