Hi there. My twin cooler fans on the front arn't working at all. Any ideas where I should start troubleshooting?
2007 Honda CRV
Open hood. Prop open.
Star engine. Turn AC on.
Check to see if both fans turn on.
If not check relays in the engine bay fuse box.
Thank you, I'll give it a go. I should have mentioned, I'm referring to my 2004 Hyundai Terracan as the vehicle in question.
Also unplug the connectors from the fans and check for voltage at the connector.with the same conditions that AVISITOR noted. It is possible that one fan has not been working for some time.
Thanks for you help all. It turned out that my fans were seized solid (maybe it has been stood for some time). Also, one of the fuses had blown on one of the fans itself. I have new replaced them with a pair I got local for a decent price.
