I need to add resistors to my turn signals in order to use LEDS
Does anyone know which wires in the headlight connector I need to use?
No, we don't. Because you posted in the wrong forum and we don't know what model of Santa Fe you own.
No problem, Nick. Here is the forum relating to your model....2013~2019 DM Santa Fe Forum
And here is the headlamp connector pinout for your car. You should be able to figure out what wires you need to connect the resistors to from that. I assume it would be Turn+ & Turn-....
456330
