I'm having an issue with the passenger side front turn signal in my 2011 Elantra. It isn't working, but the bulb isn't burnt out. The fuses are good and the headlight is working fine. The wiring harness going into the head light assembly also appears to be in good shape as well.
However, If I take it out, re-seat the bulb and put it back in it works fine until I shut the car off again. Then it stops working again.
Any suggestions on what could be causing it?
