I got a Tucson 2012 model and now the 4X4 warning indicator is continuously appearing in my dashboard. Mechanics were suspecting the actuator motor has gone and replaced with a new one (slightly different) and still the indicator is on. Seems the wiring got some kind of issue. Anyone who got any ideas to check the actuator motor and wiring line for the same to make sure is with electrical wiring line or with actuator motor? kindly help.
You have a new motor? If so, it leaves wiring.
What's 'slightly different' mean? If it's not the right one you'll need to get the right one.
Replaced with the kia sportage model one. All are same, but I had a doubt whether its slightly different
If it's the correct part and is good you need to check the wiring at the solenoid. Check with your DVOM.
