Hello everyone. I bought this care a year ago, 130k miles. Short time after that de Service Engine Light came on, and the test at the auto parts showed codes P0700 and P0741,
which is Torque Converter Clutch Solenoid Circuit Performance or Stuck Off.
Since I was told that I could run the car until some visible failures changing gears be manifested, and then decide to fix the problem, but until the present I haven't seen anything abnormal,
it was as if the car had no problem, but a few days ago the car stopped while driving. I try to start it, I hear it turning, but the engine doesn't get to start.
Could it be possible that the problem with the solenoids in the transmission gets to a point where this can happens?
I appreciate your help.
Thanks.
Hello & welcome to the forum.
I doubt a gearbox issue would prevent the engine from starting. This isn't the correct place to discuss your problem though. You should start a new thread on the Tucson forum for that...2004~2009 Tucson Forum
