41 - 44 of 44 Posts
Discussion Starter #42
hi dear
will the ECU from KIA sportage 2006 generation 2 2.0 crdi fit my hyundai tucson 2.0 crdi please.
anyone having the KIA sportage 2006 generation 2 - 2.0 crdi ecu pins diagram can please send me
thank you
kaviraj
I'm sure it will since it's basically the same car.
But you said you had already tried another ECU which obviously didn't help, so why waste more money on yet another one.
The Kia diagram is the same as the Hyundai diagram, because it's the same engine.
Discussion Starter #44
hi well another guy came from the local Hyundai agency on saturday last.
he did some tests.
i have two fuel pressure sensors which i bought on ebay
when he did a diagnostic with the first sensor on it gave P0192
when he removed the harness from the sensor it gave P0193
he cleared the DTCs and replaced the sensor with the second one
he made a diagnostic and it said no fault recorded in the ecu but still the vehicle doesn't start.
however, i noticed that the glow lights remain on permanently and doesn't switch off as it should normally within 10 seconds of ignition and the engine check light doesn't turn on at all
while surfing the internet i came across this ( please see attachment)
however i don't have the high scan pro to do it.
do you think that its the engine check and glow plug lights that are preventing the vehicle to start ?
please advise.
one thing more, i haven't bought another ecu am using the same ecu
regards
kaviraj
41 - 44 of 44 Posts
