Truck cuts off when I put it in gear!!! I’ve had the maf sensor,wires,plugs,ignition coils changed!!! Rough idle and backfire also!!! Code P0302!! Help I’m ready to throw the whole truck away
Same thread
You should really post your results to the original thread you started. It can be confusing for those that wish to help when you keep starting new threads like this.
Whatever happened to the timing belt install check? Do all the timing marks line up? You stated previously that this began after a timing belt change. Backfiring is indicative of a timing issue.
