I can only pump a couple gallons before the auto shutoff is triggered on the pump. I have this problem at different gas stations so I know it isn't the pump itself. It seems something is clogged and the gas isn't getting through to the tank fast enough so the pump thinks I am full. Is there an inline filter or something?
Thanks in advance.
There is a tank filter located on the fresh air side of the charcoal cannister. If you live on dusty roads or have submerged the back of the car this can get plugged. You may want to replace the cannister close valve at the same time as they are prone to sticking. If you see any charcoal particals in either the close vave or filter then the cannister will need to be replaced also.
