Defect on the vertical piano black trim next to the passenger side mirror. Gap at the top on outside. Not sure what is behind it. Can water get in and accumulate to cause rust? Rubber seal is too short inside, the tension pulls the rubber hook almost out of the hole. The driver side is fine. Anyone has this problem?
440985
440986
440987
Got the problem fixed today BUT created other problem due to careless and/or inexperience. The window upper chrome is scratched when they pryed out the vertical piece, and long scratch along the bottom when they removed the seal, and the door edge now sticks out and there is a click noise when pressed at that area. Unfortunately the manager on duty left already and the service advisor can't make decision.
Is it that difficult to remove trims? They should assume all rigid trim pieces are not reuseable after popped off; otherwise the cycle never ends!
441546
441547
441548
