03 v6 automatic. Anybody know where the transmission vent is? Or is it just the dipstick tube?
Trans temp? What's the vent about?
The transaxle temp seems to be getting a bit high. Nothing catastrophic. Just seeing if I could locate the vent to be sure it's not clogged up. Just trying to rule things out
I doubt a vent would help in tranny fluid cooling, better effort would be to look at the cooling lines and cooler assy. located in the radiator area usually at the bottom.
How many miles on the car? When was the tranny fluid last changed? Are you reading the temp with a scan tool or do you have a gauge on that model? What is the actual temps you are seeing?
