I have a 2001 hyundai accent GL the transmission has started shifting hard when it shifts into drive. It shifts fine and smooth from first to second but when it shifts into drive it hits drive hard and sometimes it acts like it doesn't want to shift and if you let up on the gas it will go ahead and shift, but when it shifts to overdrive it seems fine but hits hard when it down shifts back to drive. Also I have noticed a couple times when it goes to shift into drive the engine seems like it revs up some but when you let off the gas it goes ahead and shifts. Can anyone tell me what might be the problem?
Mine does the same thing, change the fluid and keep you foot on the brake until it engages and it will be fine , the problem is the clutch pack is worn and a tranny is more than it he car is worth so drive it until it doesn't go anymore and don't beat on it.
just to state the obvious, we're talking about an auto trans here?
and yeah sounds like clutch packs. thats rebuild territory. you can try a fluid flush (proper one!) but usually at that point its too late.
