Hi, my girlfriend has an 02 Accent with an automatic transmission. The passenger side output shaft seal keeps getting destroyed by a wobbley cv axle shaft that has developed slow low clunk under acceleration. I'm pretty sure the trans output bearing is worn out. Does anyone know if the bearing can be removed with a puller and knocked back in with a bearing driver? Or is this a remove transmission, split casing, hydrualic press procedure? The car works well other than this issue so i'd like to try and save it if possible. I'm interested in knowing if I can do it without the hydraulic press, it doesn't have to be pretty or even recommended.
Thanks for any help.
