I have a possessed Accent. Lately my car has been dropping out of 4th gear while driving on the highway. This does not happen all the time. I don't drive the car on weekends normally as I only use it to commute to work. I can usually drive to work the first day no issue, second day I may or may not have issues, by Wednesday I start having the issue on the way home and by Thurday/Friday it happens on the way to work and way home. When this does happen it will not shift back into fourth and when you come to a stop the engine seems to be accelerating from 2nd not first. Turning the engine on and off can reset everything but it usually happens again.
I do have a CEL for a rear O2 sensor but other then that nothing else has shown up. I had it into the dealership and it didn't act up. I had it to Mr. Transmisison and it wouldn't act up. I had the Tranny serviced and the problem is still there.
I have had it suggested to me, and reading forums it makes some sense, that it may be the TPS.
Anyone have a similar problem or heard of the same problem that may have a suggestion where to start?
Thanks
Thanks
