1 - 9 of 9 Posts
Can anyone give me the information on the transmission hose that goes onto the radiator. I need to know the upper is for what and the lower is for what. For example lower hose is for receiving back and upper hose is the sender from transmission to radiator. I've been looking all over Google and forums, it doesn't give any information. This is my last hope here thanks
2007 Honda CRV
Why do you need this information?
Are you planning on changing the cooling lines for the transmission??
Does it really matter if it works???
May be if you run the car on a lift and disconnect one of the lines to see if it is squirting fluid out or not?
Oh, if you need a genius helper then put an ad in the newspaper
You'll get a better response ... lol.
<----------- Genius
@2011MengerSonata The return line on the cooler is the higher of the two. If you look under the battery there's 2 lines, the on on the left looking down from the top is the hot trans fluid going to the cooler. The on on the right is the cool transmission fluid going back into the transmission.
What exactly are you trying to do?
1 - 9 of 9 Posts
