You can always VERIFY what the dealer says by looking in the little black maintenance record booklet in your glove box. It gives a run down, by months/mileage, of what services are recommended, at what interval, from a simple "inspect" to a "replace."
Not familiar with your model's particular schedule, but that little guy is a quick place to find out. Someone on here will know, Checkers.
:00000732: to the forums.
Pretty sure our transmission is a sealed unit and doesn't require that the fluids be changed. I just looked through the owner's manual (section 7) and all the way up to 150kmiles, not once does it show to either inspect or replace the tranny fluid.
You can change it if you choose, clean fluid never ruined a seal or shellaced a fiber disc changing it' friction co-efficient.. auto trans is 1 of them things that clean oil goes a long way.. lifetime trans oil, dont think so..
Old rotten fluid ruins seals, shellacs friction discs changing friction co-efficient, and makes for goofy shift feeling
My dealer gave me a "dealer version" of the little black maintenance record, complete with 3000 mile oil changes, etc. I wrapped it up with the paper floor mats and threw it in the trash.
It is 60k under severe and it is not as easy as the non-hybrid, so it should cost more labor wise.
There is a module over the fill hole.
