1 - 8 of 8 Posts
I've just bought Elantra Manual with 107k on it. I want to change out the transaxle oil, I got the oil from Hyundai at it was cheap, $7.50 per qt, it takes 2qt for the change but I bought 3 just in case.
For ref the oil is:
MANUAL TRANSMISSION OIL SAE 75W-85 1 QT EACH 08950-00020B MT85(75W80 GL4
I can found a guide for the early model Elantra's and plenty on auto fluid swap, but not so much info out there for the manual.
I know there is a 24mm drain bolt to remove, but in one video they show (it maybe an earlier model though) another bolt on the front of the transaxle which you use to fill it up, I cannot see one on my car, any idea where it's located?
It should be a large thin flat hex. On my Accent it sits horizontal pointing towards the front. 15/16" socket fits better than the 24mm.
I need to change the fluid on my Accent this summer. I have some gently used RedLine MT85 in it now. It came out of my Gen coupe after 5k miles. Nice fluid though. I have put CeraTec in the Gen Coupe and it really improved the smooth shifting. I'll add some next time. If I do a new fill of the RL MT85 it will be the last one I assume. :(
1 - 8 of 8 Posts
