i want to check the oil in my 5 speed elantra but i cant find the fill hole for teh transmission. i followed the instructions in teh owners manuel and teh onlt spot ive found the looks like a fil plug is practically on teh bottom of teh transaxel its o literally on teh bottom edge of teh housing. the owners mauel shows a pic showing it as around teh centerline of the front left tire(i think it the left side) for the fill plug and facing the drill for teh drain plug. thiis makes no sense to me so if anyone can help id be much obliged. thanks in advance.
The drain plug is at the bottom of the case (lowest potion so oil drains out)... 15/16 -- 24mm hex
The fill plug is half way up the radiator side of the trans case about the middle, has a 17mm hex head.
QUOTE (sbr711 @ Jun 21 2010, 07:06 PM) index.php?act=findpost&pid=335068
thanks thats what i had thought but my manuel seems to show it backwards
