1 - 9 of 9 Posts
The car is 1-1/2 years old with 21,000 miles. It started shifting funny through all gears when cold about 5-6 months ago but maybe only once a month. It gradually increased to twice a month then once a week for the past 1-1/2 to 2 months. Each time I call the dealer they tell me that I can make an appointment but if it's not shifting funny when they test it there is no way to tell whats' wrong without a code. I tried making a couple of appointments but had business appointments that got in the way so I had to cancel (the car wasn't shifting funny at the time anyway). yesterday night it started shifting funny and continued this morning through the afternoon non-stop. Finally the trans light came on today and I checked the code with my scan tool when I got home. P0711 (Transmission Fluid Temp sensor circuit) came up. It's going to the dealer tomorrow morning. I hope this isn't a big issue. Has any one else had this issue? If so, what did it end up being? Did they just have to replace the sensor?
Here is the service bulletin pertaining to your situation.
Your service department will probably do this.
I was on my way to the dealer to take the car in when the car started shifting normal again. I thought ahhh! They're going to say they can't duplicate the problem again! But the check engine light stayed on until I arrived to the dealer. I told them about the code P0711 and they checked it. It did turn out to be the sensor after all. The job took about 1-1/2 hours and I'm back on the road again with smooth shifting. I'm so glad to have finally gotten this shifting issue fixed.:grin:
I hope they improved those sensors for the new models, instead of continuing to use a faulty part like the starter levers.
good point! i wonder if this tranny fix is covered by the wonderful powertrain warranty?
I want to thank everyone that posted on this topic. Including the link to the technical bulletin. My 2012 Sonata with 40,000 miles started acting the same way a couple months ago. I thought it was due to the fact that I don't drive it much. The engine light came on the other day. AutoZone identified the code and I went straight here.
I'm glad that you all pointed out the warranty coverage, as the dealer tried to charge me $728 for this fix. Thanks so much. Buyer Beware and always use google!
1 - 9 of 9 Posts
