1 - 8 of 8 Posts
I've done the transmission fluid drain/fill on my 2012 Sonata (YF generation) a few times over the years. Has anyone done it on the LF? Is it the same transmission? I believe the fluid is a newer spec...any other changes?
YF transmissions,from what others have reported,had a 24 mm fill plug(top of trans).I can confirm that LF transmissions have a 22 mm fill plug. Guess they are going for weight savings...:smile:The side plug also looks a little different,other than that,its basically the same trans.
The trans filter is not serviceable, so keep the fluid clean. If the filter is clogged then it's 6 hours labor
6hrs,, that just simple trans in & out... Warranty trans replace is almost 4hr,,, customer pay be almost double,, and we not allowed to split case of auto trans at dealer level
Anyone know how long these transmissions last if you never touch the fluid? I've done the fluid every 40K on my 2012, it's got 163K on it.
2017 Sonata Sport 2.0T
sbr711 , I know you repair these but if it was your Hyundai what would you do for trans fluid change intervals?
I've heard that at 60k miles was a good interval to change the fluid at but would love to know if it needs to be done sooner. I'm not sure how i feel about "lifetime fluid". Worst comes to worse it can't hurt to change the fluid sooner than later.
60 be a fair interval. Clean ATF wont varnish friction discs & brakes for gear sets, or other internal parts..
5-6 bottle of new ATF is cheap compared to a $1700 Hyundai Re-Man, maybe 6-7hr shop rate labor, ATF and can of cooler wash if you had to pay for it
1 - 8 of 8 Posts
