1 - 1 of 1 Posts
I have a 99 hyundai Elantra with the 16v 2.0l ,w/ automatic tranny..
My problem is that the car will go into drive but has problems up shifting and reverse does does not even work... I have taken the pan down and put new fuild in it and a new filter but with no help... I took the pan down again and had my dad go through the gears and one of the solenoids is chattering ,it just makes this tapping sound as it goes through each gear ,, I think its the reverse solenoid because it faces the front of the trans away from the rest of the 3 solenoids.. I can't figure out whats wrong and why the tranny only works in every gear except reverse??? Please help me out !!!!!!
update
The pan was clean and no metal in the pan and fuild does not smell burnt and the mill light is not on and i hooked up my basic scanner and no codes came up
The tranny would pop out of gear and have to be put in neutral and then back into drive and it would go back into gear..
1 - 1 of 1 Posts
