What does the TPMS light indicate? It's not the low pressure light. That's a different light with a tire icon with an explanation point. This is just the letters TPMS. It doesn't show up on an OBD scanner.
445813
That’s probably a light to indicate a problem with the TPMS like a faulty sensor or whatever instead of just flashing the low tire light like other cars do.
As 2424Goldie says, that light means there is a fault. I just wanted to add that you can't read TPMS trouble codes with a generic OBD scan tool. Cheap generic OBD scan tools are only able to communicate with the engine ECU. You need a more sophisticated/expensive tool to be able to diagnose TPMS faults DIY. Just taking the car to your local garage would probably be the cheaper option.
What does the TPMS light indicate? It's not the low pressure light. That's a different light with a tire icon with an explanation point. Visit AutoGuysLand to review obd2 scanner if you want to buy one. This is just the letters TPMS. It doesn't show up on an OBD scanner.
View attachment 445813 View attachment 445813
It could be one of sensors is bad. then, you have to check your tire by looking for yourself.
