1 - 20 of 782 Posts
Friends, I want to upgrade to remote lock and I can't explain much and I'm sending pictures below. Hope pictures speak louder than words.
Is that connector for remote lock wirimg harness? Please explain about on the uses of that connector and does it relates and have any purposes for the use of remote lock? Thanks.
That's factory wiring and your car doesn't have factory remote locking, so it can't be the connector for remote lock wiring harness.
You don't need to do anything with that connector when installing a remote locking system.
Did you buy a remote kit yet?
No ..I have not bought it yet.
But also I've been struggling to find solutions on videos on internet.
One particular videos shows :
the car comes factory central lock fitted. All they did was just make a tapping on the wires of the driver's door switchs/connector corresponding to the lock and unlock position with the wires coming from the remote control unit of the remote system. This is done only on driver's door. After tapping, they test with remote key and everything works perfectly.
Surprisingly no such a single actuator were used for the functioning of the remote central locking!!!
I want to install myself to my best the remote locking to prevent unnecessary extra wiring harness and maintain minimum defects, scratch, etc. on the car.
Looking forward for your assistance. Thanks.
The car in that video must have already had an actuator inside the driver's door to move the lock. Unfortunately, many Hyundai cars do not meaning you need to install one and the wiring required to power it.
Sir, can I do tapping on the pins of the wires from the BCM which corresponds to the lock or unlock wires coming from the door latch switch connector to activate the remote lock or unlock system.
You can...if your car already has an actuator (electric motor) inside the driver's door.
If your car doesn't have an actuator you will need to install one and wire the output of your remote locking unit to the actuator.
Discussion Starter #8
Sir, I found the following information.
1. Connector with 4 wires of the door latch of the driver's door.
2. Wire of the output connector of the BCM which only lock all doors.
Now, interesting part. In particular to case no.2 above,
I join one end of testing light to the wire(positive) of the output bcm connector while the other end to ground(-ve). Thereafter, all doors locked automatically.
But, im confused how to unlock all doors as I couldn't locate the corresponding wire for unlocking all doors. Or I'm in working in wrong harness output BCM??? If such wire for unlock is found, definitely we are on the verge of finishing installing remote lock.
Sir, would be highly keen to know how to set up remote lock system. And any info on locating the correspinding pin numbers for lock or unlock function will be a quick access to set up this system.
Thanks in advance.
Discussion Starter #9
Sir,
Yes, I join one end of testing light to the dark green colour of the output BCM connector and the other end to negative ground. All doors including driver's door locked automatically. Picture attached herewith.
1.How to find unlock wires of the output BCM connector notice that the lock wire has been located on the same output connector?
2.How to locate lock and unlock wires on the input side of the BCM connector as this input side has more pins and similar colour codes than the output?
With due regards and once again awaiting your best solutions and advise. Thanks.
I assume you have probed all the other wires on the two BCM connectors with you test light, and haven't been able to find a wire that unlocks the doors?
As I explained in my reply to your recent PM, there doesn't necessarily need to be a lock and an unlock wire. Sometimes both functions are performed using a single wire. Maybe that's why you can't find an unlock wire using the test light.
Discussion Starter #11
Ok, sir, the wire which locks all doors is on the output connector of the BCM.( I guess I'm on the output BCM connector since joining the wire locks all doors regardless of whether doors are opened or closed, and please correct me if I'm wrong.) Picture attached herewith.
Yes, I joined one end of test light to the dark green wire of the output BCM connector and the other to ground Which locks all doors.
And again, I joined one end of the test light to the yellow/black wire of the output BCM connector and the other end to ground too, which then unlocks all doors.
Am I in right output BCM connector, and if I'm wrong, how to find lock and unlock wires on the input BCM connector.?
Very much grateful and really appreciated your concerns on this issue and hope you may kindly guide me until the installation is finished.
With due regards, thanks.
dark green wire... locks all doors.
yellow/black....unlocks all doors.
Great, each function has it's own control wire. That makes wiring up the remote locking box a little easier.
I don't think it really matters on your car whether you connect to the input side of the BCM or the output. That would only becomes significant if the car has a factory alarm system which yours does not.
Discussion Starter #13
Sir, to be on the safer side, please help me locate the correct wires on the input BCM connector...
And, assuming that the control wires of the remote control unit are connected to the said wires of the output BCM connector, will any current interference arises if accidentally I press the lock or unlock key which sends pulses to the said wires and at the same time sending signal manually by physically movie the lock handle on driver door.
I would like to also connect the remote locking in full set with the alarm system too in particular.
Thanks.
Discussion Starter #14 (Edited)
Also, the dangerous case...and for security purposes. "All doors can be locked or unlocked even if any of the 5 doors remains opened.
Thanks.
Wiring the windows isn't that difficult. You will need to route at least two wires into the drivers door for that though.
Does the car have electric windows front & rear or only on the front doors?
Discussion Starter #17
Yes, all windows are electrically operated up and down by their respective switches on each doors.
The driver door has got a master control switches to operate all windows too.
Also, only the driver window rolls up and down automatically when the switch is push up and down fully. This interesting particular function is not available to other windows. Can it be applied or make wiring harness to other windows too so that just pushing the switches button up and down on each doors rolls windows automatically?
And, sir, I guess wiring harness for open or close windows are also located on the input BCM connector.
Once again, awaiting your help. Thanks a lot
Discussion Starter #18
Sir the remote control unit is yet to arrive in 4 days time.
Please help me with the connections wiring harness for auto close windows.
Thanks.
Discussion Starter #19
SEARCH IN THE CURRENT
AND SHOW ME
Thang Tons
online
Member
Join: May 2018
Aug 05, 2018 · #1
To remote lock
AUTOSPARK
Senior Member
Join: Nov 2014
Mentions: 97
Scotland, UK.
Aug 05, 2018 · #2
Thang Tons said:
Original Post
grcauto
Senior Member
Join: Jul 2018
Mentions: 9
Flint, MI USA
Aug 05, 2018 · #3
Thang Tons said:
Original Post
Thang Tons
online
Member
Join: May 2018
Aug 05, 2018 · #4
AUTOSPARK
Senior Member
Join: Nov 2014
Mentions: 97
Scotland, UK.
Aug 05, 2018 · #5
Thang Tons said:
Original Post
Thang Tons
online
Member
Join: May 2018
Aug 29, 2018 · #6
Sir, can I do tapping on the pins of the wires from the BCM which corresponds to the lock or unlock wires coming from the door latch switch connector to activate the remote lock or unlock system. Pictures attached herewith.
AUTOSPARK
Senior Member
Join: Nov 2014
Mentions: 97
Scotland, UK.
Aug 29, 2018 · #7
Thang Tons said:
Original Post
Thang Tons
online
Member
Join: May 2018
Sep 02, 2018 · #8
Thanks in advance.
Thang Tons
online
Member
Join: May 2018
Sep 05, 2018 · #9
Sir,
AUTOSPARK
Senior Member
Join: Nov 2014
Mentions: 97
Scotland, UK.
Sep 07, 2018 · #10
Thang Tons
online
Member
Join: May 2018
Sep 07, 2018 · #11
AUTOSPARK
Senior Member
Join: Nov 2014
Mentions: 97
Scotland, UK.
Sep 07, 2018 · #12
Thang Tons said:
Original Post
Thang Tons
online
Member
Join: May 2018
Sep 07, 2018 · #13
Thanks.
Thang Tons
online
Member
Join: May 2018
Sep 07, 2018 · #14
Thanks.
Post Edited
Thang Tons
online
Member
Join: May 2018
Sep 09, 2018 · #15
Yes, finally got order this remote locking unit which which be arriving shortly. This unit comes with auto close windows.
And, sir you got to help me again with the wiring harness for auto close af all windows when the car is locked.
Thanks.
AUTOSPARK
Senior Member
Join: Nov 2014
Mentions: 97
Scotland, UK.
Sep 09, 2018 · #16
Thang Tons
online
Member
Join: May 2018
Sep 10, 2018 · #17
Again, I'm not familiar with your particular model of car but generally on Hyundai cars the windows are completely separate from the BCM.
Post the wiring instructions for your remote unit when it arrives and I'll try to advise you on how to wire the windows to it. If your buying the one you posted the picture of earlier I doubt that will be able to operate the windows directly. There doesn't appear to be enough wires on the connector to accommodate central locking and electric windows. You might need a separate interface to close the windows.
I'm sure there is probably an aftermarket kit you could fit to make all the windows work in a "one touch" fashion, but personally I think it would be more trouble than it's worth.
1 - 20 of 782 Posts
