Stock are 205 45 16, wondering if the 55s I got from a friend will have enough clearance. Anyone tried/ know?
That's about a 1.5" difference in height.
They may fit, but the question is, are you ok with messing up your speedometer? The speed sensor is calibrated to a certain tire size, so if you change that you’ll be throwing off your speedo, for example if you change to the larger tire a larger tire will spin less than a smaller tire, causing your car to think it’s going slower than it actually is.
Will that fit? Looks like it could by my amateur eye
