Any tips on replacing the radiator core support? I had a front end bang-up and I am removing the front bumper & headlights, then replacing the radiator support and front bumper. Tips like "make sure you get that hidden bolt behind bracket A" or "remove part x first!" or "rotate the part clockwise to fit thru the hole".
Thanks!
- Jeff
Question
Thanks!
- Jeff
Hey bender24k, aren't the front air bag sensors attached to the radiator support? Did you do anything special or did you disconnect them before removing the old support? Thanks. I want to change mine too.
