How many of you have actually replaced the timing cover gasket when you replace the timing belt? Is it really critical that this gasket be replaced? I am asking because my gasket was brittle and it fell apart when I pulled the timing cover off.
Thanks,
Sean
Unfortunately, I don't have all of the pieces. I really need to get the car back on the road this week and I am wondering if it is safe to drive without the gasket fitted to the timing cover. Thanks for the reply man.
You can drive it,, it just an aid to slow down water/dirt intrusion into timing cavity.. bad part is you need to take the drive belts/covers off to install rubber to groove in cover.
A little bit of 3M weatherstrip glue hold rubber in so it dont fall out while install, or few dabs of RTV will work
