1 - 9 of 9 Posts
My excel has 190k KMs on it proberly have to change the timing belt at 200k was wondering if I should also change the water pump
Thanks not sure if it was done last round belt looks good shape Il do it at 100k thought I might be able to get away with it all these kits without water pumps out there more not then with
My '08 Accent has a difficult water pump pulley. Promblem is short bolts and limited space. I use a longer bolt to first start in one of the holes on the pulley. Then line it up and put in the small bolts.
1 - 9 of 9 Posts
