Engine Mechanical problem
1999 Hyundai Accent 4 cyl Front Wheel Drive Manual 119,00 miles
I broke my timing belt. Not sure how much damage I have sustained and I am aware this is interferance engine. I need instructions on how to disassemble the timing componants, and remove the cylinder head, so that we can inspect the damage. I am aware that just asking this question leads you to believe that I am not a competant tech. I just don't want to make any mistakes in the removal and make the job go as smooth as possible if you understand my meaning. I do have a more experienced tech to reassemble the engine after I get it removed. Please advise on the proceedure I should use to remove these componants.
