Hello, I changed the spark plugs in my 2002 hyandai sana fe v6 and now when i start the car the engine revs and the rpms shoot up to around 7 instantly. there is a spring that i believe is the throttle return and it has no resistance. does anyone know how or where it is suppose to connect? please help, thank you, kevin
Did you happen to monkey with the cruise control module? If you remove the cable to the cruise unit under the hood and over-tighten it when replacing it, the cable will get jammed in the open position.
