I took some lame pictures but I am puzzled. I have not taken anything apart other than the air box to look at why I have drips again. I was going have it serviced but guess I need warranty done on it first.
Its puddling under the engine mount but as you can tell the top of the transmission case is also sorta stained. Does anybody know if there is an overflow vent on top of the case?
Gotta be an overflow/vent tube. Do you do your own mx? I wanna say it could be someone spilled a fluid while servicing the vehicle.
I've seen this once before...
Something you can try,
There are 4 motor mount bolts,
remove one, inspect hole and then replace,
continue until you find ATF. You might not.
The only oil that I see is the red under the motor mount and it doesn't look like much. Let us know what the dealer has to say. I think they will use a rag and screwdriver to clean it up or blow it out and see if it reappears? Has this happened on your auto before and has it been to the dealer for this problem? A little oil goes a long way.
